Pollys13
- Wiltshire UK
Trap is a, AFG3/8'' Compressed Air Compressor In Line Moisture Water Filter Trap AF3000-03.
Air filter adopts novel vane design with high division efficiency and differential pressure discharge device.
This moisture water filter can discharge water automatically.
Used to filter moisture and impurities in compressed air.
With has high filtration accuracy, long service life, safe and reliable.
Water trap filters adjustable pressure is, Pressure adjustment range: 0.05MPa - 0.85MPa,
7.25 psi - 123.28 psi "
If I pressurize the pot to 40 psi, everything works fine.
I also have a low pressure regulator and gauge that is sensive enough to read down to 1 psi.
I want to use 5.5 psi, when I set the regulator to pass air at 5.5 psi I hear air passing through it. The tank is starting to fill up but the water trap is releasing air at the same time.
When get water trap problem sorted out, assume pot will fill up at 5.5 psi albeit, much slower than if was filling at 40 psi?
As I say filling the pot at 40 psi, everything is fine, no air coming out of drain on trap. Though on occassion I think the trap was letting out air at other pressures, though nowhere near as low as 7.25 psi.
This started me thinking the trap might be faulty, then again problem could be caused by trying to run at 5.5 psi as the range of the trap is 7.25 psi - 123.28 psi ? "Also would the pot fill up.... eventually, between 1/2 a pound and two pounds of pressure?
Anyone any ideas?
Thanks.
Anyone any ideas?
Thanks.
