They were great on the phone and it's clear to see the machine is low mileageThats a shame. IFL were very helpful in repairing ours. Not awfully expensive either, they replaced the control PCB (not the main board)
Drop hitches for moving trailers, just no tow balls on it yet.What's that upfront, a snowplow mount ?
Why two?Drop hitches for moving trailers, just no tow balls on it yet.
It's for smashing A hole BMW drivers out the way...What's that upfront, a snowplow mount ?
Why two?
Makes moving them easier, depending on which way your turning things, units can be 50ft x 14ft wide and moved through gaps barely big enough, even when pulling ie reversing having the hitch offset helps get round corners
Do you use:It's for smashing A hole BMW drivers out the way...
I've run into the back of an almo rental car in my own which has different winch bumper but similar hitch assy, land rover 1 hire car 0, it wrapped the rear of the hire car neatly around the front, pushed the boot to the back seats, crumpled the roof and jammed the front doors, hit it at about 45mph after the idiots pulled out from a side, after an hgv had passed them right Infront of me on the A1.Do you use:
1. Ramming speed ?
Or
2. Ludicrous speed ?
Just a nurf into the barriersDo you use:
1. Ramming speed ?
Or
The "PIT Maneuver" then eh ?Just a nurf into the barriers![]()
