Mornin' all!
Having found all the info. I can about running fixed air pipe around my workshop walls, I've decided to go for John Guest 22mm. rigid nylon pipe. Now, some of the recommended layouts I've looked at show vertical pipes from the underneath of the main line with ball valves at the bottom to drain off water.
My problem is, I can buy the John Guest piping and couplings (straight connectors, equal Tee connectors, elbows etc.) for this piping from Toolstation, but nowhere (including John Guest!) shows ball valves or water traps for this pipework!
Also, in view of the larger size of air pipe, would it be an advantage to connect directly to the end of the Compressor tank rather than to the small PCL coupling on top of the tank?
Any ideas or advice would be much appreciated!
Thanks,
VL1500.
Thanks,
VL1500.
