Hi, been as I've had to enclose my compressor to drown out the noise, I've had to wire all of the controls externally. This might be useful for someone soundproofing a compressor or generator, or who keeps it in a seperate room. Obviously adding a starter motor is pretty straight forward. I've also added a 12v solenoid valve to take the load off the pump whilst trying to start.
The more complicated task was wiring a solenoid to operate the choke. I saw a kit for sale on the net, but the guy wanted 200 quid! My way costs around a tenner and takes around 15 minutes to install.
First I drilled a 4mm hole into the choke lever, cut the metal arm to a suitable size and bent the ends to prevent them falling out the holes.
After Bit of lining up and trial and error, I drilled two holes in the engine cover to mount the solenoid.
The solenoid I purchased from maplins. It was around 8 pounds, they can be had cheaper on eBay, but I prefer going to the shop and physically seeing something before I buy it.
Next, you have to cut away some of the plastic that surrounds the choke and fuel levers to stop the solenoid rod from fouling it:
This is the final product. The solenoid has two wires coming from it. If you reverse the polarity it pulls, switch it back and it pushes. The switch you need to operate this is a double pole double throw switch. In one position it sends 12v to the blue wire and earths the green one, if you flick the switch down it reverses it and sends 12v to the green wire and earths the blue.
Hope this helps somebody, and I'll accept any constructive critism. Now I just have to build a suitable sound deadening enclosure!
