G G-10 Member Messages 15 Oct 19, 2010 #1 Quick question. I need to key the paint on my car what grade wet and dry sandpaper should i use. 800?, 1200? other?
the snooper getting older by the day Messages 21,063 Location Hull UK Oct 19, 2010 #2 what paint solid or clear over base, celly or 2k
the snooper getting older by the day Messages 21,063 Location Hull UK Oct 19, 2010 #4 think id use 1000 gritt flat further then you need to flat (unless its a full pannel) but dont paint that far then polish both new paint and old
the snooper getting older by the day Messages 21,063 Location Hull UK Oct 19, 2010 #6 steveo3002 said: 800-1000 wet is a decent key , dont go any finer Click to expand... if its a blend 800 can leave marks behind or original paint a little thin for polishing
langy langys rodshop Messages 6,095 Location London Oct 19, 2010 #8 800 would be better in my opinion
steveo3002 Member Messages 7,517 Oct 19, 2010 #9 the snooper said: if its a blend 800 can leave marks behind or original paint a little thin for polishing Click to expand... he never mentioned a blend , if its a blend then scotch pad the fade out area if you go too fine on general keying it wont give the new paint enough grip
the snooper getting older by the day Messages 21,063 Location Hull UK Oct 19, 2010 #10 steveo3002 said: he never mentioned a blend , if its a blend then scotch pad the fade out area Click to expand... he never said it wasnt either so i added that bit in case
