puffernutter
Puffernutter
- Wiltshire
You will laugh at this, but some will sympathise as it was a bargain!
As some will know I recently bought a laser/engraver from here. It was without a chiller and various people and sites warned me against buying a chiller from China as they were just a fan in front of a radiator and relied on a low ambient temperature to work (although to be fair, some were happy with them).
I did some hunting on the internet and found a secondhand Laserpure20 chiller local to me. Now I (will have) a 50W laser, the Laserpure 20 is designed for 20kW, so I have a little headroom there! Unfortunately I cannot find a manual for it! I have been in touch with the manufacturer in the states and they don't have one. It is fairly basic and some connections are obvious, but there is "water - laser in" and "water - laser out" (I can cope with that). There is also a "water in" (it has an inboard tank, so that makes sense). But there is also a "water out". All I can assume is that is a drain? There is an internal valve, I know not what it does! (I have studied the plumbing, but I probably need to draw it out!) Finally there is a strange connection on the back that I am not sure if it is electrical or fluid!
So, you seem to have a tremendous "reach" has anyone come across a manual for a Laserpure 20? (There is one you can find quickly by Googling, but that is to do with the water you use to cool it, not the cooler itself - I found that and it has some odd bits of use, but it isn't an operating manual.
Cheers
Peter
Cheers
Peter
