scotto75
- Bristol
Hi,
I've got a Sureweld Monomig 101 that has a leaky torch even when the machine's not turned on. As soon as you press the trigger, the gas comes out the nozzle and with the regulator opened to full I can get 10l/m on the peashooter. But as soon as you let go of the trigger, I can hear the gas coming out of the torch.
I have opened up the torch and turned the regulator on full and can feel the sound of the gas leak change as I put my hand over where the pipe connects to the white solenoid housing, so I assume the pipe connection's loose, as opposed to the solenoid pin stuck, etc, especially as the solenoid appears to be working fine when the trigger is pressed.
My question is whether anyone has had experience of dismantling a torch like this and if it is possible to fix the loose pipe connection, assuming that my diagnosis is correct?
Any advice much appreciated!
![Photo2008-07-2015200620192026.jpg](http://i951.photobucket.com/albums/ad355/scottfury/Photo2008-07-2015200620192026.jpg)
