im just priming on bare metal that has been blasted with lechler 2k epoxy 29107
im using lechler hs hardener 00362,ive never sprayed 2k epoxy before so im not sure about much, using a devilbiss flg gun at 2 bar with the trigger pulled, the problem im seeing is that the spray coat seems to be going on clear?? its only the first coat and im spraying it lightly to avoid runs but surely it should show more colour?the paint is grey when mixed by the way,the panels have been washed in panel wipe and cleaned with a tack rag,any ideas?
