Park_monkey
hello all.
I have a chain block and tackle, and want to build a couple of a frames with a crossbar to enable me to use it. It's only a 500kg hoist and I plan on using it to lift engines out of cars but also I would like to be able to put it on the back of my recovery truck so I can lift the back end of a car up to drive another underneath, enabling me to put two cars on my truck. The reason for this is I race bangers and hire them out so regularly have two on my truck and one on a trailer.
What spec steel would I need to use? I would like it height and width adjustable, I was thinking around 75mm box for the main uprights, with slightly smaller inserts that I can slide in and out to make it taller or shorter. It won't need casters when on the truck but it would be useful if I could put some on to move it around on the floor. Will box section be ok for the crossbar to will I need I beam?
Any advice on steel sizes greatly appreciated, it won't be carrying any massive weight so the lighter the better.
Thanks
Dale
Thanks
Dale
