Seano
- Devon
I had to send our Lorch T220 ac/dc basic plus back to the suppliers yesterday with two faults...the amperage selector pot has gone haywire...when you adjust amps it appears to work ok, then the numbers in the Led readout stop moving, and sometimes even start to reduce down the scale
and the torch function plug...that weird one that has flat blade terminals that go into a female socket with the round holes on the front of the machine is really sloppy, you can wobble it from side to side and up and down, in fact it is quite difficult to get at to turn through 90% to lock it as its buried right under the the top dinse connector...so consequently the lock ring at the back of the plug now has stripped threads because the lazy arses at work can't be bothered to to unplug the dinse plug to tighten the torch function plug, my own opinion of both of these fault are heavy handedness because the monkeys we employ just don't give a S**T about how they treat equipment which makes me sooooooooooooooo mad....
