On the settings you quote above both those units are exactly the same. It’s just how they are laid out is differentWould anyone have the specs on a handytig 200 or t220 looking for the AC Freq,AC balance,pulse ac/DC, slope up and down and gas pre and post flow.
Thanks
That’s exactly the point behind that panel. All the settings are still available to play with but they are in the sub menu out the way.I've got a HandyTig with the black FR32 pedal. I like this pedal over the FR35 because it's not as bulky and has a much lower profile so it more comfortable to use when sitting down. Don't make the mistake I made when I first got it and panic that it's the wrong pedal because the plug doesn't fit the socket on the front of the machine - there is a dedicated pedal socket at the back of the machine so that you can leave both the pedal and torch connected.
So far, on mild steel and aluminium, I've not really altered many of the parameters in the sub-menu because the pre-set percentages and time settings work well enough. I've had a play a few times but I've had more to gain by improving my technique than playing with machine settings. This has been a bonus for me in comparison to manual machines with lots of individual settings because it can be confusing to remember what settings are needed individually when changing material.
