ned
- Eire
Hi, ya necessity did its magical thing again, I had to made this on saturday to complete a job im working on.
I didnt see a design like this online, I'm posting it here in the hope that others looking for similar will come across it.
The basic idea of a rivnut is that the top 7mm of the rivnut crumples / deforms and this is what creates the bond with the parent metal.
Trying to use a spanner is a kak idea and will just lead to fustration.
You start by welding two nuts together, make three of these, then weld them around three central nuts. The first one I made , one of the sides fell off due to the high pressures i was exerting on it, so make sure its well and truly melted together.
MK I: one of these broke off, really you need three bolts in the middle to increase the surface area available for welding. you can see below i only used two for the central part, later i improved this.
the gap beween the rivnut and the tool body is for a metal plate to sit in.
This is what the bolts press into / against when you are using it. See bottom pic.
The two bolts are needed becuse if you use one you will strip the threads on the nuts, or the bolts, whichever gives first. Use grade 8.8 bolts and nuts.
you can see the metal plate in this pic.
the metal plate below is part of the tool, the bolts are pushing against this to deform the rivnut. I think the plate is 5 or 6mm, needs to be fairly hefty.
hope this is useful to someone sometime. Once its sorted its a very effective tool. fun to use.
