Steve Lawton
New Member
- UK
I am having a problem with regards to selecting a process for an application.
Initally, the assembly was to be MIG welded but concerns of brittleness at the joint of the parts have neccessitaed that the joint is brazed. Intially I have been looking at furnace brazing but due to inconsistant fit up of the mild steels parts it does not look like I will be able to furnace the parts due to excessive gapping between the components.
The alternative that I am looking at is to MAG braze the parts which will fill any gaps that may exist between the parts.
However, the main concern that I have with this is that I am unsure if there will be an brittleness created with the MIG brazing process, as I am informed that if a furnace brazing method is used then the parent metal becomes annealed and thus removes any potential brittleness in the joint.
Please advise which process I should suggest.
Thank you
Steve
Thank you
Steve
