well you wont need a pressure washer with your finger over the end of the hose pipeWhats an acceptable mains water pressure? I am getting 6 bar/90PSI and am wondering if this is a tad high and whether I should fit a pressure regulating valve.
that wouldn't stop the initial build up till it lowered flowJust turn the stop tap down till the cold water doesn't bounce out and soak you.
For that looks like you've peed everywhere look.ours is quite high father inlaw used to turn the sink tap on and get absolutely soaked up his jumper![]()
more chance of getting a burst and more damageFifteen years ago, My son bought an old Victotian house that needed everything doing to it, When we connected the mains water the pressure was tremendous, The pumping station was only half a mile away, Checked it out with a pressure gauge, 200psi, fitted a reducer to get it down to a much more acceptable level, Its been OK ever since, but never known mains pressure so high,
