azazello
New Member
- italy
I own since a few weeks a little telwin welder; it came with flux equipment and I learned to weld sheets of metal without gas, with the proper animated wire.
Last week I bought a tank of ar/co2 mix and the kit for linking to the welder.
Unexplicably it seems unable to solder well enough with this new equipment.
An expert friend of mine came to try and help regulating the gas flow but with no result.
The welder works very well in the flux configuration, melting the metal and making good joints, while in the mig configuration it just builds up balls of metal without melting the metal I would like to joint, and the two pieces usually come apart too easily.
In the photo you can see the long and regular weldings made in flux configuration and the metal blobs made in the mig configuration. ..
I always thought that with the gas the welDing quality could just be improved...
Thank you all guys!
Thank you all guys!
