hi all,
a question for those in the know,
we all know that welders are rated in duty cycle
i.e. 180 amps @30%
150 amps @50%
100 amps @ 100%
my question is as follows, in the real world are these ratings the same for both MIG and MMA i.e. would a MIG at 180amps weld 8mm plate whereas an MMA would only weld 6mm
the reason I ask is that MIGS use constant voltage whereas MMAs use a varying voltage and current,
does the speed of wirefeed also impact the mig, if you have the wire feed speed turned down low on the mig would the 180 at 30% become 180 @ 50%?
also from using a MIG once turned up good and hot mind you, the amount of welding that you would get done in 3mins would be equivalent to that you would get done in 5mins with the MMA?
thanks,
aidan
i.e. 180 amps @30%
150 amps @50%
100 amps @ 100%
thanks,
aidan
