yngndrw
New Member
Hello,
I was hoping for some advice on a hobbyist home mig setup. I am limited to single phase but I have the main consumer unit close by so 32A (Or even 64A) isn't an issue. I'm looking at inverter units so that I can actually lift it myself and also for the stepless controls.
I want something reliable so I've been discounting the nameless stuff on ebay, but I also don't want to spend a fortune. I had initially been looking at the R-Tech 180 units so that was my baseline price of around £500.
The R-Tech units are of course very limited, no synergic settings and doesn't even seen to have adjustable inductance. Obviously there's no hot start or crater filling either.
Another contender was the Kemppi MinarcMig Evo 200 available for around £1000, again new with warranty. I believe this has a slightly lower minimum current and has full synergic control but again none of the really fancy options.
That leaves me with the big spanner in the works, a used unit with all of the bells and whistles. A Kemppi Pro 3200 with full pulse controls. Now this is a very old (Discontinued) unit with no warranty, but the fact that it's still working tells a story in itself. This has everything: Synergic control, hot start, crater filling, pulse and even double-pulse. This is a big three-phase unit which requires a 13.3kVA power source (With a 320A limit at 100% duty cycle!), but I've worked out that I can adapt it to run from a 32A single phase supply with a power limit of around 8kVA - Based on the rated input at its maximum power, I think that would allow me to run it at around 190A. The price for this including the parts to adapt it to single phase will end up to be around the £1000 mark, so this is in direct competition with the new MinarcMig.
Pulse is very interesting as it would allow me to use spray transfer on smaller parts in more realistic orientations. Spray interests me because of the lack of spatter - Honestly I don't really have a need, but my thought is why exclude myself from that when it's available for the same price.
So there you are, three main options: (Or any others you may suggest)
1) A cheaper option, R-Tech 180 @ ~£500
2) An expensive new option, Kemppi MinarcMig Evo 200 @ ~£1000
3) An expensive old option with all the bells and whistles, Kemppi Pro 3200 with the MXE pulse mig panel @ ~£1000
Thanks,
-Andrew.
Thanks,
-Andrew.
