Hi i have an old Miller Maxstar 150 with the separate Soft start 1 unit underneath. I had just finished using it the other day and had the earth lead on a bit of plate i was using to rest the job on. I put the torch down on the plate and after a few seconds the torch started arcing out and the HF was buzzing. I switched it off and lifed the torch away from the plate and then switched it on again but now it constantly buzzes. I took the casing off this afternoon and traced the problem to one of two things. The resistor (at least i think it is) is getting very hot! Or the circuit board for the HF. There is a contact with a small gap that was arcing all over the place (can be seen in the pic bellow) so i cleaned that up and got a better spark and hoped that had fixed it but no. So do i need to try and find the HF curcuit board or the resistor or could it be something else? Thanks.
Resistor?
HF Circuit board
Resistor?
HF Circuit board
