arther dailey
- England
anybody replaced a mitsi l200 2012 b40 clutch master cyl.? according to manual you need to fully strip complete dash !! I am hoping to go in from the floor.....
thanks for reply , thhe blead nipple is only 5 mm away from bar so cant even get blead tube on,saying that nipple is overly long so possibly get shorter one on it then either back bleed as you suggest or eazi blead the sucker. cheersTry back bleeding the system , connect a hose from the nearest brake bleed nipple to the clutch bleed and pump the brake pedal to push air upwards through the clutch system
thanks , its fact that pedal is flat on floor, presume through air is what concerned me , hadnt had that before . will persevere untill its sorted.cheersI had a right mare getting my brothers to bleed after we did a clutch on it. Persevering is all that seemed to work!
Hi, thanks for the interest , yes thats what I am thinking connect ezi bleed direct to slave bleed and go from there , Milners just called back.the tech guy , went through procedures as I have done them, he suspects duff master cylinder (very quickly) which makes me think its happened before, and is sending replacement . In the mean time I might try and isolate master and bleed seperate . there is a horizontal(ish) pipe accross but like brake pipes if pressure is there from master it should nt cause any grief .cheersYou may be able to connect or adapt the hose from your Ezibleed to fit directly onto the bleed nipple? I have a spare section of flexible hose that I use which fits my Sealey pump up pressure bleeder . From memory ,doesnt the L200 have a long horizontal run of pipe across the rear of the engine bay which traps air?
Urghhh, so fitted second new master , yes that pressurises up to clutch damper , so I tried reverse pressure and I can get fluid though dribbling out that from slave , but connect it up , attempt to bleed , tiniest dribble .pedal on floor. Presuming the damper is foobar or holding air , so looking at getting bypass hose for that so you have the "normal" master straight to slave . some what testing my patianceIf you can get a vacuum bleeder connected you should be able to back bleed the syste
