Afternoon chaps. A wee issue, which I wasn't aware I had, and need some help please.
Compressor is a Clarke, twin pump on a 270 litre. Drained regularly, and always has a lot in it.
Output is via a 3/4 pipe to the filters.
Filter/Reg is a 15 micron for moisture and dirt removal.
Filter 2 is a 5 micron.
Filter 3 is another 5 micron, same as filter 2.
then a PCL dropout.
Then my "clean" take off - this is where I connect for spraying and dry work like plasma.
then a lubricator for air tools.
I have a new hose for paint, which goes to the belt filter pack on the air-fed mask (devilbiss), and then a short hose to the gun, which also has a small moisture trap on it before the mini pressure regulator.
The problem is a few micro-spots in the paint finish, which I can only attribute to moisture. So my question is, how can moisture get through all these filters? And what more can I do to prevent it please?
Thanks.
then a PCL dropout.
Thanks.
