Mr Fro
- Bury st Edmunds-ish
I've been inspired by the recent thread about "hard wiring" air supply. My compressor is now in the other side of the workshop and out from under the bench which is great!
I've run 22mm copper up the wall and below the joists to a drop down near my benches. Total run is around 7m. I used 22mm for the highly technical reason of that's what I had.
The questions I have now are regarding connections: My tank had 3/8" thread so I'll get a full bore 1/4 turn valve for that but how do I connect it to the 22mm copper? Chop a bit of air hose with some bayonets?
Next up is the regulator/drier - I've got a small 1/4" one kicking about somewhere. Is this good enough or should I be looking at something bigger? I'm not in to blasting or anything but would like to future proof myself.
Finally air hoses. What's a reasonable size? I've got a scabby 8mm plastic thing now so I'll be getting something nice and flexible probably 10m long. I'll be running the usual suspects - ratchet, impact wrench etc.
I'm mindful of adding restriction and undoing the point of the large bore copper or am I over thinking things?
Cheers,
Fro
Cheers,
Fro
. Ah well, trip to Ridgeons tomorrow then.
