markythesparky
- lancashire,uk
My airmaster tiger 9/50 compressor did not work correctly found that the pressure switch had a fault on it the pressure relief part of the switch was stuck open so i fitted a new switch now all seems to work correctly, what i am wondering is what sort of time should it take to get to full pressure i timed it and it took 2min 10sec from 0 to shut off at 120 psi with a 50 ltr tank the pump is a mk93 with a 2hp motor . Also the filter regulator has stripped the thread inside so cant get it above 20psi can you get a replacement top or is it a new full unit, temporary fixed with washers behind the nut inside just set pressure with my remote one.
