miggymarky
Just done a bit of re-wiring on the motor on my compressor,After refitting i noticed its now running the opposite way to before,so question is,does it really matter,or do i need to reverse the wires?
also look at the cooling fan blades built in to the pulley it should draw the air in and across the pump for cooling if its running in the right directionPiston or screw compressor?
It really should run in the direction it's designed to. Look on the flywheel for an arrow. If it runs the wrong way there is a risk it would not be properly lubricated.
single or 3ph?
