Kram
- Sussex
Im quite new to mig welding, I got a Sealey MightyMig 130XT a couple of years ago. Im using 0.8mm Super6 branded gassless wire.
Im now trying to make a motorbike stand, which should be capable of safely holding 140-200kg off the ground while the wheels are off. As Ive not used it for a while I got some practise on some 1" square tube, 1.5mm wall. Quite happy with my practise and considering it may be good enough to use -welds are very messy but penetration seems good. I tested several welds and the surrounding metal broke instead. I would like your advice on whether I should start again with thicker, or larger tube? or if 25mm sq tube is strong enough?
The other DIY attempts I found on the web are all bigger tube, around 40mm, but most do not reinforce the welds - which I think is important as the weight of bike will spread the legs apart.
http://www.superhawkforum.com/forums/general-discussion-30/home-made-abba-type-stand-17787/
http://www.benelliforum.com/forum/tornado-tre/9555-homemade-abba-stand-2.html
http://s130.photobucket.com/user/mantaopel/media/P1010355.jpg.html
This is my practise so far - tomorrow Im hoping to finish it which will include:
Reinforce welds with more tube across, 45 degree angle.
Feet, so it is stable.
Supporting tubes for each each side of the spindle, a second nut on end.
Also plan to use M12 rod. Ends of the rod will be ground down to 7mm/10mm to fit inside the bike swing arm bolt. I think 1" is overkill as long as its supported, and my drill only goes upto 13mm !
