gasket999
getting there...
- Manchester, UK
Howdo folks.
I appreciate that which compressor should i buy has been done to death, but just wanted to check my garage electric specs with some of the more knowledgable folk here - I'm aware there are a few sparks on the forum.
My garage is fed by a 10mm2 cable running from my 100amp main consumer unit in the kitchen (this cable is currently protected in the CU by a 50amp MCB) it runs approx 16m to a second, dedicated garage consumer unit which has a second set of MCBs comprising of the usual small MCB pair for lights and sockets, but I also had a third, dedicated 32amp MCB installed which feeds a single industrial 32amp socket - like this.
The big socket was fitted with the view of using larger tools in the garage - and now its time to buy my compressor. I've been trying to get second hand units to work and have decided to bite the bullet and get a big one from MM on their VAT free day this weekend. Am sick of little ones not going me enough air so am going to get the biggest I can safely run from my supply.
But how big can I go on my power supply? I understand that the power/current drops with a longer cable and mine is very long at 16m.
Ideally I'd like to invest in one of the monster tandem motor units - the se37c270nd (2x4hp) or the smaller se29d270nd (2x3hp) - these require a 30amp minimum and I'm not sure I have that given the length of the cable.
Some of the biggest 1ph single motored ones actually ask for a 40amp supply - such as the SE18C200ND.
Could anyone offer any advice? Is the current set-up advisable, would it be better to reduce some of the MCB sizes for safety and restrict myself to a smaller compressor or would I actually have the potential to increase them to offer a better supply to the garage?
Of course, any changes will be done by a certified electrician - I'd just like to know I'm asking for the right thing.
Really appreciate any advice.
