Morning electronics gurus.
I've got a mate's NAD power amp here to have a look at. His electronics know-how is zero, mine is just above.
It developed an intermittent static type noise in the right channel yesterday, nothing too major so he carried on using it. He turned it off then a bit later when he turned it on it was in protection mode.
He brought it here for me to see if there was anything obvious, blown cap, signs of heat, cracked solder joint etc. but I could see nothing obvious.
After a few minutes of having it powered on with nothing connected, the speaker protection relay clicked in and the indicator light went out.
I found this was repeatable so it makes me think it's a failing component which starts to work normally as it warms up.
I hooked it up to my system and it ran fine yesterday and continues to do so now, in fact, it fired straight up this morning.
I briefly heard the noise yesterday, it's akin to someone putting their hand lightly over a microphone.
Any ideas of a good starting point to try and identify the fault?
*A bit of history - may be relevant: I spotted the impedance switch on the back was set to 4 ohms, he said that's how it was when he bought it in the 80s and he's never touched it. It turns out his speakers are 8 ohms and yesterday morning he bi-wired them for the first time.
Here's the schematic.
