Jbo2231
- essex - UK
Hey everyone,
After a year of saving and finally getting in to a place with a garage and workshop i am able to put my money towards getting some decent tools and setting up my workshop. As I do quite a bit of automotive restoration i want a compressor to help things along and to start doing more work myself rather than paying others to do it for me.
I was wondering if any of you have any experience with the following compressors and could help me make a decision? (open to other suggestions not here as well).
I will be using it for media blasting parts such as suspension components, painting, sanding and pretty much anything you can use air for around a car. Having chewed through a "Cheap" SGS direct drive compressor in less than a month i want to buy the correct one that will last for years to come.
I am limited to single phase and a 32amp supply and have a budget of ~£1200 including VAT. it will be in a residential address so want to try and keep the noise down as much as possible, however it is a compressor so noise is a given.
I have researched the following and currently favour the FIAC, but wanted your input before going for it:
MAGNUM STX-30-270 : 270L tank : 30CFM (21 FAD) : single phase : ??amp : Cast Iron cyclinder : £1200
FIAC workhorse 2x3hp : 250L tank : 28CFM (18FAD) : single phase : 30amp : Cast Iron cyclinder : £1281
Clarke XE29/270 : 270L tank : 28CFM (??FAD) : single phase : 30amp : Alu cyclinder : £1246
Bonus 100L tank from the broken compressor (Motor has burnt out due to overheating)
Despite being the most expensive my theory is that the FIAC unit is the one that isn't pushing its motors or pumps to achieve better figures than the competition and so should be the most reliable while also meeting my requirements. It also benefits from on-site warranty (although im not sure this includes residential)
I know i could probably get by with a cheaper less powerful unit but was thinking the more powerful the unit the longer it should last and will be running less. It should also be plenty future proof if i decide to take my hobby further.
Any thoughts or corrections about the above? sorry if i missed any threads comparing the above but i could only find passing comments regarding them individually.
Thanks in advance!
James
Thanks in advance!
James
