storm monkey
Cluless Expert!
Evening All,
Today I received a new Draper 40A plasma cutter (model 70066) and have been having a play but not everything is going as I'd hoped. I got the cutter on a very chunky 32A supply direct from my consumer unit, with a massive compressor hooked up, all assembled and ready to go. A pull on the trigger produces a strong pilot arc which lasts for about 5 seconds before cutting out, which I assume is what is supposed to happen if you don't start cutting with it. Anyhow, I found some scrap, and set about cutting it into tiny pieces. Generally, it cuts. It flies through the thinner stuff and was getting through about 6mm. but starting to look like quite a scruffy cut. I have not yet managed to get a constant and smooth cutting motion but assume this will help. I've started to find some "quirks" however that I'm not sure about and want to figure out if it's me or the cutter! I know I have a lot to learn but want to make sure the machine is good before I pull my remaining hair out.
Firstly, if I pull the trigger away from material I get a great pilot arc but as I approach the workpiece, it goes out. It's like the arc is trying to transfer from pilot to workpiece earth but doesn't manage it. If I start with the tip on of very close to the work, it arcs up and generally continues cutting however. It this normal? It makes it very hard to start a cut right at the edge of a piece or metal as I seem to need the torch further on to the piece before it will maintain an arc.
Secondly, sometimes whilst moving the torch, the arc just dies. If I go over a gap (e.g. a previous cut line) it also dies. I can understand the gap but not whilst moving the torch along flat metal. It could be the way I'm moving it I guess. I've tried with the torch spacer fitted and dragging the tip on the metal surface. Both are a little iffy on certain cuts, then fine on others. Could it be the metal? All of my test pieces were fairly rusty or previously painted.
Thirdly, Once the arc is lost, it wont re-start unless I release the trigger, wait for the 10s cool down then pull the trigger to start the pilot arc. I can occasionally see tiny sparks at the tip once the arc is lost but it won't re-light. It is making it very difficult to get a decent cut line. I'd assumed the hf meant it would re-light, and it has very occasionally managed it. I've tried giving it the best chance by cutting a freshly cleaned bit of metal but that didn't help.
Any suggestions or advice greatly received.
Phil
Phil
