mpats
Hello (hopefully) frendly people of the arc welding section. I've posted thi in my introduction thread but thought I should probably post it here as well to get all the feedback possible, All constructive criticism is welcomed, if it means I get better then it's a good thing in my book.
So I'm using an old AC buzz box that a friend from work was looking to get rid of. It would have been rude not to have taken it especially when it was free (my favorite kind of price).
So I started on a large piece or plate I had from work, must be 15-20mm thick, so started laying welds along it to get the hang of getting nice straight welds. Then I moved on to butt welding a couple of pieces of 35 x 6mm flat iron bar (courtesy of good old B&Q).
Now I must admit it was more an exercise in practicing joining 2 pieces so I didn't do a v groove to aid penetration but welded it on both sides, as opposed to a proper commercial job
. It seems to be fairly strong, probably good enough for something I'm knocking up in the workshop. I now it's not good practice and for a proper piece of work I would, but i didn't do much in the way of surface prep double
So, I decided to cut the last inch or so off to see what was going on inside the join. as you can see I had a bit of trouble when I had to use another stick, getting it started was a PITA and resulted in the last inch or so of weld being, shall we say, cr*p!
You can see the slag inclusion (I think thats the right term) now right at the bottom of the weld after the cut away piece has been removed.
So the other side went a bit better, managed to get the second stick going far better on this side. You can see, just about half way down (or slightly above) where I started the second stick, not the small void on the left but just above it.
So here's a view of the cross section, shows the join of the 2 pieces and the reasonable penetration (minus the small void just where I cut it (typical).
The reasonable side, showing the full length.
So a quick run down of what I did was A single straight weld down the middle, the bar has slightly rounded edges which helped. This was done one one side then the other (to prevent bowing). Then i laid down a weld either side of the center weld centered on it's edge, again one weld at a time on each side. Then to finish it I welded across the top of the 3 using a wave motion to cover over the edges of them.
It seems pretty sturdy, but out of interest I shall be taking the small cut of piece in to work on monday (I'll be to busy over the weekend to get the time but monday should be a bit quieter) to put it in the press and see what sort of load/pressure it can take.
all the best
mal
all the best
mal
