David Mitchell
New Member
- Plymouth UK
Hi all not long joined the forum, just purchased a used Clarke SE16C150 2005 model.
I was told it worked fine but would not cut out and needed a new pressure switch.
When I opened the box that contains the capacitor I found the wires were all burnt out and melted, and they were not connected to the overload switch which had disintegrated. I knew I should have seen it running but it had just been pulled out of the guys shed and he had no power, but promised me faithfully it was fine, so as it was cheap I took it. I ordered a new switch and capacitor and connectors from Clarkes. The switch and capacitor I received are different from what is fitted, the switch is round and from the Boxer model where mine is square and the capacitor is shorter with a nut on one end and only two spade connectors on the other. The original has no nut is a bit longer and has four spade connectors three only being used, so looks like they have sent the wrong items.
I also ordered a new pressure switch, the same model that is there now a Condor MDR1-EA/11. The new one arrived today and it is slightly different its a Condor MDR 1, which has a push fit for the small pipe that runs to the non return valve. I have a copper pipe that is not a push fit there now, do I need to also buy a NRV with a push fit and new plastic pipe, or is there another way to get round it?.
Sorry its such a long question but I have no idea about compressors and any help would be very much appreciated, thank you.
