Hi,
whenever I need an answer to a fabrication question I usually end up here, such a wealth of information!
So here's my first post, don't laugh!
So been using a Mig welder for a few years now, hobby use, done a bit of Tig and stick, so not really a newbie but not terribly
good at any of them! Treated myself to new Mig the other day and this particular model apparently calculates wire speed/volts
according to amps required, works quite well to although I think it actually calculates voltage from the set wire speed and amps
requested, however this got me to thinking
Why does wire speed affect the current?
As I understand it, in short circuit transfer, the wire
touches the metal heats up rapidly, melts, breaks the circuit then makes the circuit again because of the wire feed pushing the
wire back to the workpiece and this can happen several hundred times a second.
So why would pushing more wire in increase the amps? perhaps increasing the wire speed would increase the arc frequency ?
I think that this might possibly be where the answer lies, the definition of an amp is
"the ampere is a measure of the amount of electric charge passing a point in an electric
circuit per unit time with 6.241 × 1018 electrons, or one coulomb per second constituting one ampere."
so as an amp is defined as current flow/time then by increasing the frequency of the arc you are
increasing the current flow (amps)?
or
maybe it's too early in the morning and I'm overthinking this?
Please let this be the answer, it's been driving me nuts!!
or
