Gaz
Hello to all,
My name is Gaz, and I'm completely new to welding. I have bought my self a very cheap Arc welder which I have been practising with today. I have been reading through the forum to try and get as much info as I can take in to get some idea of how to go on.
The pic's below are the last ones I have done today. I have used up about 10-15 rods while practising. The rods I used have come with the welder and they seem very old and the thinner ones of the two packs seem to be falling apart/crumbling away... which I don't think is helping me any.
I need to learn the technique of actually using the Arc "is there a pattern" or movement to putting the weld down? and I need to know how do you calculate the rod required for the steel used and the ampage needed????
Also I have a welder question: the welder shown in the pic I have been using today and the light on power switch never worked at all. But while doing the last bit of welding the rod burnt down to around 1.5" long then the welder cut out, But!!! the power on light is now on when you turn the welder on, but the welder has no sign of life. I assume this is the thermal cut off? if so, does the light just operate when the welder is "cut off" rather than working 100% of the time?
Sorry for the long post, any help would be greatly appreciated...
Gaz...
Gaz...
