N nixboy13 Member Messages 77 Nov 21, 2012 #1 im welding a trailor made form 1/4 inch angle iron what is the best rods to go with i have a box 0f 3.25 wll these be ok thanks
S superls Member Messages 252 Nov 21, 2012 #2 sorru i cant advise technically, but just try a scrap piece to see it it is ok.
madkayaker Pro sparkey Pro Welder Messages 13,678 Nov 21, 2012 #4 3.25 should be ok might be a bit hot but turn the amps down to the bottom of the range on the box and see how you get on
B Bsmith Member Messages 2,554 Location Leyland UK Nov 21, 2012 #5 I imagine they are mild steel general purpose rods eg, 6013s. They will be fine for 1/4" thick mild steel and for welding in all positions.
S spaf4 Member Messages 39 Nov 21, 2012 #6 You should have no problem using 3.25, and if you're new to this game and don't mind me giving you a couple of tips, then, if you have any, use 2.5 to tack up with and never tack weld in corners. Good luck with the trailer.
