hi, this is my first post and i have a problem with my welder, if anyone can help or try helping i thank you in advance.
i have a draper MW135AT welder it allows for 0.6-0.8 wire but 0.9 was fitted, it worked for a day. next morning it stopped working. it would strike an arc but the wire feed is not working. The motor have been taken off away from gearbox to see if the shaft is turning but it is not. i have unplugged the motor and tested the the feed and it is getting 24v no matter how much the wire speed knob is turned up, it even gets 24v when the torch trigger is not pressed (should this happen?) the welder is not old and hasnt had much use its just needed now for restoring an mgb
any help really appreciated
cheers ross
cheers ross
