Hello everyone, I've registered here to ask the some experienced welders a question...
I used to work as a mechanic and we had a MIG welder that I used quite a bit and was ok at, by no means to a high professional standard though.
When I gave up mechanicing I bought a cheap arc welding kit from BnQ for odd bits of welding I needed to do.
I've never been able to get to grips with it properly, I know the welder is no doubt of poor quality being from BnQ and only cheap but I can't get a good looking weld from it, I can run a line of weld and it looks good until I chip off the slag, the slag chips off after a lot of battering but the weld has the slag included in the weld metal (excuse my lack of using the correct terms).
Although the metal is joined I doubt it's as strong as a complete weld line and it also looks terrible, pitted and like a birds splatted on it.
Is there something I'm doing drastically wrong, like the wrong amperage, going too fast etc. I'm using machine mart rods (I'm guessing not the best) 2.5mm usually and around 80amps, I also struggle to get the arc started, it usually just sticks to the base metal again is this due to bad equipment or a wrong set up or just me that's useless at it
