Davek0974
****!, Drink!, Girls!
- Hertfordshire
Hi all,
My compressor is a new 8cfm unit with a 50ltr tank, has one regulator and twin outlets on it.
I just got a new air impact wrench and it needs 90psi max, so I thought I would drop the regulator on the pump to 90 but if set at 90 without air flowing, when I operate the wrench, it drops to about 40psi then goes back up when the flow stops. If i set 90 with air flowing it goes up to125 when flow stops.
Is it normal to have to adjust pressure regulators only when air is being drawn off or does this indicate a crap regulator or something else??
Btw the air line is 8mm rubber about 10m long.
We have larger air lines at work and the regulators stay the same whether air is flowing or not apart from a little drop at the instant flow starts.
Dave
Dave
