miggymarky
Got a slight air leak from my oil fill cap.is this normal or not.
It constant stream.rtbcstrea 521664 said:Is it a constant stream or does it pulsate with the pump? Is it a single or twin cyclinder pump?
On a single cylinder pump I'd expect air to be blown in and out of the breather. On a twin cylinder pump I wouldn't expect any airflow through the breather.
The breather is there to allow for expansion of the air in the crankcase as the pump warms up and to vent any blow-by past the piston (s).
I never understood the reason for the non-return valve - Landover owners usually dispense with the steel ball on the axle breathers.
Too much air coming out of a breather indicates worn rings or leaking gaskets.
Really? It's there for a reason. To prevent water getting into the axle as there's only supposed to be oil in there. Even a Chelsea Tractor could see some deep water on occasion and too much would soon knacker the axle/diff/wheel bearings.
