Mark Harrison
- UK, North Derbyshire
Hi, just got an old special Uno Tig from an auction. It has a foot pedal wired in along with a button on the torch. I have only used lift permanent live torches before. Thanks to folk here I swapped it to single phase and gapped, and cleaned the HF points to 8 thou. However the HF start seems really hot and miss, and the current seems to die quite quickly. I am sticking in 2T mode, pressing and holding the button, then pressing the footpedal, if and when it ignites. I have walked the current up, the scale has lost its markings and sticks at the bottom end. The Argon is the same as I was using for lift,but I would say the tip seems to oxidise faster even though I now have post time. Any suggestions to try for this simple DC mild steel setup? I had thought to purge through the argon gas side, and check for leaks .After that it may be the skip/ offered here as not working!
Cheers,Mark
Cheers,Mark
