Evening all.
I appreciate I'm walking with the experts here and am all ears for advice and suggestions.
After years of making the tea, grinding off rusty surfaces, passing and holding stuff and watching welders at work I've decided to take the plunge myself. At last I'm going to learn how to weld properly. It'll mean buying a decent sized welder to replace my little one and taking it steady but, before I retire in 18 months time I'm going to do it.
For now, with a friend, I'm about to start building my workshop in readiness. It will house all my tools, woodwork and metal work and will shelter me from the elements while I'm working on all my retirement projects. The workshop will be a steel H frame 45ft x 25ft and I can't buy a standard size portal because the roof pitches are too low and I want to keep the eaves low and at the same time have space for an upstairs storage room.
My friend has been great, welding all sorts of stuff for me over the years. He's skilled and has a 230 amp Sealey (230 volt) mig welder but I can't keep relying on him for everything I want to do in the future.
We were going to weld some 10mm thick mild steel footplates onto some old 9" x 4" x 10mm RSJs but last night he tried a sample and kept tripping the RCD on his home electrics. He's worried he might damage his welder if we just upped the ante with cable/larger fuses.
This is where I need the advice please.
What's the best sort of welder for this type of job? We only have single phase power here so I guess we can't go much bigger than 230 amps. Might an inverter be a better idea than a mig and if so what sort of size would that need to be to weld 10mm plate?
Failing all that is there someone out there in the Leics/Northants region who alreadyhas all the kit and would be prepared to do the job for me at a reasonable cost? It would be for 8 footplates and another 8 plates on the ends of the cross members (102 x 230 x 23) to bolt onto the columns.
It won't be for some time yet, since planning permission takes at least 12 weeks and it has to be properly done, so there's plenty of time to weigh up all the alternatives.
Thanks for reading all this. Any/all advice would be gratefully received.
