Hi, i'm welding a Mini at the moment, chosen to use Oxy/acetylene, but i've come from an AC tig background.
Sometimes i'm getting a sort of 'fizzy' weld pool which is giving a porus weld. What causes this, and how can i prevent it? (btw i've chopped out the rust and am welding to good clean metal)
Onother problem i'm having is that when butt welding a patch in, the weld will hold on one side but then crack on the other side of the patch as it cools. I've tried playing with nature of the flame a little, but i don't really have the experience.. should i use a slightly oxidising flame.. light acet, adjust till no soot, then add oxy till yellow flare goes (neutral flame) then add a little more oxy, till the larger cone nearly meets the smaller cone. Is this right?!
BTW, i'm using a boc 3 tip
I've had to chop out an extra section 'cos the weld was all porus.. (this bit VV) not good enough!
Thanks for any help
Nathan
Thanks for any help
Nathan
