Ragnarok
Enthusiast
 - Wales
hey,
is it posable to use a murex saffire 5 with welding nozzles and propane gas? but only for brazing not welding? or are the welding nozzles out if you don't use acetylene?
since getting the tig i see no reason that i'd use my O/A for welding, but may want to braze and will want to cut with it, so just checking if it's welding nozzles can still be safely used? no need to have an £80 a year cylinder sitting around if i could replace it with a calor propane plus fills are cheaper and no collection charge
thanks a lot everyone
sounds as if your not heating the metal up enough and the rod is getting 2 hot and blowing away spitting and farting. use flux and keep the blowtorch tip on the metal and feed the rod into the flame and on to the metal gently as it melts. if it blobs and bursts the whole jobs 2 hot
