Is it not the chemicals used to remove brake dust that are causing it to go dull?
I have refurbished quite a few sets of alloy wheels. I have had some complaints that gloss/shine fades away after a few months.
What is causing this?
At the moment i use max meyer 2k lacquer.
Thanks
you could be spraying in to cold of weather to loose the gloss later on.are you using solvent base or water based metallic on your wheels.If you are using water base ,and the base is not fully dry 99% dry it will absorb the clear coat like a sponge. Causing the semi gloss look.
