Hi Guys, wonder if any one can help with this problem, painted the bonnet of my rs2000 a few weeks ago, bonnet was stripped to bare metal, pre wiped, etch primed, primerfillerd, 3coats of base coat black, then clear coated, this was painted in a both, the next day there was millions of pin spots under the clear and when tried to wet sand and buff they apear to get worse. so far this has been done 3times and getting a bit sick of spending pennies now, it seems to be a problem between the primer and base coat because its deffo under the clear. could it be the primer not dry enough after wet sanding, altough it was left in the both to dry out, any help welcome CheeRS Dave
