DAPPH
as dyslexik as I'm daft
Has anyone got or set up a decent extraction system using a vacuum cyclonic separator discharging into a round barrel , supporting three or so extraction tubes of say 10 foot lengths of around 60 mm flexi wired reinforced translucent pipe off a 100 mm plastic main drain pipe chest with screw on sealed caps on the ends in case of blockages . A system that can be set open or closed up with wooden plugs & tubes removed if not in use .
If so have you got any thoughts or advice especially about a spring seated flap valve below pepper pot of holes in the sealed screw on gasketed barrel lid , that unseats if the vacuum gets too great due to blockages in the inlet pipes off the machines . Any thoughts on an anti static bare copper wire running through the chest into the cyclone & earthing it out etc. ? What size vacuum machine is desirable, could it be a simple hot ash vacuum sucker .
All advice welcome as I'm researching things for setting up three or more such cyclone extraction points in our Men's Shed .
