MattH
- Cornwall
In our CNC workshop we make lots of small engraved items from MDF (hundred's of custom pieces a week). I have a number of sanders for finishing the most useful of which is a drum sander fitted with a brush type flatter head.
But it's slow and you have to stand there feeding everything through, because of this it mostly gets used for larger pieces with lots of carving on the top.
I end up unloading an 8x4 sheet from the Router onto a downdraft table a manually sanding the edges of the products to de-nib them with a cordless palm sander.
Most of these products are in the 6"x6" range.
What I would like is a large vibrating plate with sand paper attached flush mounted in a bench so I can just hold the piece down onto it, flip the piece and repeat (imagine a DA sander upside down bench mounted).
Does such a thing exist? If it does I've never seen one.
Now I think I'm going to end up building one but how would I power it? Could I use two random orbit sanders attached to a plate (12" x 12" sort of size) or would they just fight each other?
Or should I hard mount a proper motor under neath with an offset weight and mount the whole affair on vibration mounts???
Thoughts?
Thoughts?
