acme]hello
all members
please help me to work out the problem .
i need such type of chemical which can slove the problem of steam leaking from the welding work . i have one small vessel. in this vessel, i produce heat till 250 degree centigrade by the boiling of water.and pressure creaeted till 350 PSI.
i have welded a tube in this vessel for preocess of melting pvc. i am faceing problem of leakage creating in the welding portion of the welded joint. so any one will help me to suggest any chemical which i can add with the water and my welding joints leakage can be stop.we can say this is water tube and fire is out the tube.
all members
