Looking at monopolizing on the lack of Powder Coating in my area. (If they exist - they are not well advertised!)
I've looked on the Caswell Forum, but the place is an absolute mess - Not as organised as here! So i'm looking to get some sense out of people who may have built there one on here.
So I've done some reading and I've decided i could build a decently sized one for about £700-800 with enough room to fit 4 wheels or a motorcycle frame.
Outside Dimensions 1000x1000x2000m, Internal Dimensions 800x800x1800mm. Wall thickness of 100mm. Using 4 x 1800w cooker elements fitted into 50mm recessed sections at the bottom of the over. Then using a high temp fan to circulate air from the top center and feeding it back down the rear wall exiting at the bottom of the oven.
Looking to make the entire frame from 100mm galved stud wall C Channel, comes in decent lengths for the money. it is quite thin, but with enough cross bracing and centers - it should hold itself together.
(Using this as inspiration - http://www.powdercoatguide.com/2014/09/how-to-build-powder-coating-oven.html#.VtoAGvmLRhE)
Thoughts?
Thoughts?
