pointer2null
Ready, Fire, Aim!
Got the mig all set up and started having a go. Think I'll need a lot of practive
Anyhow, after about 5 minutes of burning holes in my test scrap etc a problem developed with the mig. It sounds like the system is under load. I've had a good check for bad connections and the like, but all seems fine. When the noise starts I've notice the gas flow rate meter dips as if the gas solonoid is being operated. To cut a long story short, i think I've got some form of short circuit somewhere which is activating the mig - not continuosly but "pulsing" so the noise is actually the solonoids buzzing on and off - the sort of thing you'd get if you put a dc relay on ac.
I've got a schematic of the welder but I'm more used to micro electronic schematics and I'm not sure of all the symbols on this one:
I've labeled all the bits I know and the two I'm not sure about: ??? 1 and what looks like a cut out switch. Any ideas?
These are the bits in real life:
As you can just about see the main solonoid had a manually operatable button in the middle, when the noise starts this vibrates like hell and slowly pulls in.
Also - anyone know how to read the rotary switch diagram?
