Hi all
does anyone own one of these 10 gallon pressurised sandblasters you can buy on ebay? They all look the same - orange or red in colour - cost around £100.
I have one and it tends to clog very frequently to the point it's inefficient to use. Seems likes its a common problem and not always down to the size of the grit or compressor. Problems seem to surround the issue of moisture - and it doesn't need to be much moisture to upset it's operation. Some advise fitting a 2nd water trap and others say fitting long coiled copper tubing to the airline; inserted into a bucket of ice water to keep the air cooler and thus preventing condensation forming inside the air line.
My question is therefore twofold:
Is a water/moisture trap the same thing as a 'water separator' or 'air dryer' as I've seen on some american forums? Made of glass or plastic with a small nipple at the bottom to let water drip out.
Where do you fit it? There is already a water trap on the sandblaster - this would be a second one to improve water removal from the compressed air.
By the way the blaster works fine for blasting away rust so I do have a big compressor to run it but its just so inefficient when it clogs up after less than a minute. I find that I have to shake the tank to get the grit to fall to the bottom of the tank and into the bottom outlet hose
Any other advise would also be most welcomed. Thanks.
