brightspark Member Messages 40,171 Location yarm stockton on tees Mar 26, 2014 #2 vectraross said: what pressure switch will i need for this Click to expand... what is it a water pump
rtbcomp Moderator Messages 18,574 Location Sheffield UK Mar 26, 2014 #4 Has it got one on already? Can you show us a picture of it or where it should go?
vectraross Member Messages 70 Mar 26, 2014 #5 exactly same as this one http://www.ebay.co.uk/itm/SMALL-HIG...Air_Tools_and_Compressors&hash=item27e0ef931d
the snooper getting older by the day Messages 21,063 Location Hull UK Mar 26, 2014 #6 just ebay compressor pressure switch and find one that has then correct number of ports that you need and correct thread size and away you go
brightspark Member Messages 40,171 Location yarm stockton on tees Mar 26, 2014 #7 thatsjust got a cheap pressure switch with the red knob on it on right of the picture http://www.ebay.co.uk/sch/i.html?_t...compressor+pressure+switch&_sacat=0&_from=R40 any of these would do
vectraross Member Messages 70 Mar 27, 2014 #8 yeah i see that but mine has a big brass thing in the bottom these on ebay dont do i swop it over?
the snooper getting older by the day Messages 21,063 Location Hull UK Mar 27, 2014 #9 you will need to post a picture of yours if you want to find out what the brass part is and if its needed
the snooper getting older by the day Messages 21,063 Location Hull UK Mar 27, 2014 #11 Looks like a safety valve doesn't matter where it mounts as long as you keep it, looks like you need one with four ports plus unloader
